View the Host Control tab to see the data source for both network layer and application layer host statistics.
- Select Network Layer Host.
- Select the Host Control tab.
Host Control Field Descriptions
Use the data in the following table to use the Host Control tab.
Name |
Description |
Index |
Shows a unique identifier for the entry in the table. |
DataSource |
Shows the source of data for the associated host table. The statistics in this group reflect all packets on the local network segment that attaches to the identified interface. |
NHDropFrames |
Shows the total number of frames that the probe receives and drops but does not include in the StatsDropEvents value. This event can occur if the probe is out of resources and sheds the load from this collection. This value does not include packets that were not counted because they had MAC-layer errors. |
AHDropFrames |
Owner |
Shows the entity that configured this entry. |
